March 25, 2022 at 4:36 am
issong
SubscriberWhat's difference between TAU and Classic mesh method?
TAU ? Classic ?
Thanks.
March 25, 2022 at 1:56 pmNKC
TAU mesh creates a fine mesh at the beginning and relaxes it when smoothing whereas classic mesh creates coarse mesh at the beginning and refines it while smoothing.
TAU is well suited for curved surfaces and mainly for transient with moment analysis as there is no adaptive meshing in Maxwell Transient simulation.
Classic mesh is well suited for geometries with many thin surfaces.
If you can't decide which one to choose Select the Auto option in Initial mesh settings for Ansys software to decide which one to use.
Regards Navya
Viewing 1 reply thread- The topic ‘what is difference between TAU mesh and Classic mesh in mesh:initial setting?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
Top Contributors-
3892
1414
1241
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
