Preprocessing
Preprocessing
What is difference between Project and Imprint command in SpaceClaim?
    • Keyur Kanade
    • prajput
      Project command is used to project an entity on other entity in normal or defined direction. For this, the corresponding bodies can be away from each other.
      Imprint command is used to take imprints of bodies on each other when they are intersecting or overlapping with each other and are in proximity to each other in a given tolerance.
    • Keyur Kanade
      I want to have the faces imprinted in multibody part but not shared topology, is the Imprint correct command?
    • prajput
      You can use the Imprint command.
    • Keyur Kanade
      I have mix of shell and beam. Can I only imprint the surfaces and skip the beams?
    • Karthik Remella
      Administrator
      Yes, in the Imprint options on the left side bottom, you can uncheck box for Edge.
    • Xiaohai Wang
      Imprint 只能压印边线吧???
Viewing 6 reply threads
  • The topic ‘What is difference between Project and Imprint command in SpaceClaim?’ is closed to new replies.
