August 3, 2020 at 3:10 am
Karthik Remella
AdministratorWhat is difference between Interference and Overlap Bodies commands? -
August 3, 2020 at 3:30 am
Keyur Kanade
Ansys EmployeeInterference command identifies interfering portion between two bodies and substracts it from either smaller or bigger body based on option selected. So at the end of Interference command, there will be two resulting bodies, one with original size and second with interference volume subtracted size.
Whereas, Overlap Bodies command also identifies overlapping portion between two bodies and does boolean operations. But at the end of Overlap Bodies command , there will be three resulting bodies, two original bodies with overlapping volume subtracted from each of them and a body with overlapping volume. -
August 3, 2020 at 7:32 am
Karthik Remella
AdministratorShould I use intereferecne before share topology? -
August 3, 2020 at 10:14 am
Keyur Kanade
Ansys EmployeeYes, if there are interference in the assembly, you should use Interference tool and remove them before share topology -
August 3, 2020 at 10:28 am
Karthik Remella
AdministratorHow does Spaceclaim decides from which body to remove material in Intereference tool? -
August 3, 2020 at 10:45 am
Keyur Kanade
Ansys EmployeeBy default Spaceclaim substracts from the larger body. But you select option 'Substract from smaller body'
Viewing 5 reply threads
- The topic ‘What is difference between Interference and Overlap Bodies commands?’ is closed to new replies.
Ansys Innovation Space
1414
1220
1118
1015
