May 11, 2020 at 1:35 am
YangMie
SubscriberSometimes when I check the simulation results in Q3D, I see negative self-inductance, mutual inductance, resistance, and capacitance values. Can anyone explain what is the meaning of those negative values?Â
July 19, 2023 at 6:14 am
Waqas
Subscribervery good question, I hope the staff from ANSYS can comment.
July 21, 2023 at 1:25 pm
Dan Dv
Ansys EmployeeI'm not as savvy with Q3D as opposed to other tools, but it is not uncommon to have negative mutual resistance and inductance terms. Often that is just a function of current directionality. Negative self terms does sound more problematic, however. Can you share more about the setup that produced this result? If you are a full customer, I would recommend putting in a support ticket so that we can follow up in greater detail.Â
- The topic ‘What does the negative value mean in Q3D?’ is closed to new replies.
Ansys Innovation Space
1098
1058
1045
947
