January 2, 2019 at 12:34 pm
Donghyun Yim
SubscriberHi,
When I initialize the solution on fluent solve, the following message appears.
Warning: zone of type interior found between different solids!
Material of cell zone 14 is sus, while material of cell zone 13 is polymide.
This will adversely affect the solution.
It is recommended that you fix this issue via the TUI command
/mesh/modify-zones/slit-interior-between-diff-solids
Unless I enter the above command it diverges, but when I enter that command it converges.
I got the final solution, but I am curious of why that warning appeared.
Thanks,
Donghyun
January 2, 2019 at 12:49 pm
Keyur Kanade
Ansys Employee'interior' is nothing but the interior cells. for any boundary usually we have 'wall' type. so it it is 'interior' then solver will treat as 'interior' rather than 'wall'.Â
if this helps you, please mark this post as 'is solution' to help others on forum.
January 2, 2019 at 1:00 pm
Donghyun Yim
SubscriberSo that warning message implies the absence of wall between different interiors (or solids), and that command splits them.
If so, do I need to modify mesh before solve in order to prevent that warning?
Thanks,
Donghyun
January 2, 2019 at 1:19 pm
Keyur Kanade
Ansys Employeeno need to modify mesh.Â
select face between two solids in meshing and give named selection.Â
if you already have different named selection for this then please select this named selection in fluent and change its type to wall.
https://www.youtube.com/watch?v=-6Z2v8geroQ
January 2, 2019 at 1:53 pm
Donghyun Yim
SubscriberIf the type of face between two faces is set to be wall, no thermal energy exchange or uds exchange occurs across the wall. (as I understood)
So its type needs to be 'interface', not 'wall', doesn't it?
Thank for your kind reply,
Donghyun
January 3, 2019 at 3:58 am
Keyur Kanade
Ansys Employeeyou can set it as interface depending your configuration.Â
September 2, 2021 at 10:22 am
zahedi
Subscriberhello,nWhen I initialize the solution on fluent solve, the following message appears.nWarning: zone of type interior found between different fluids!nMaterial of cell zone 2 is air, while material of cell zone 6 is pcm.nThis will adversely affect the solution.nPlease correct the setup,nnIt is possible to help me!n -
September 2, 2021 at 4:04 pm
Forum ModeratorIf you have different fluids in a model you need either species or multiphase turned on. It's not as simple as just setting the cell zone materials. n -
November 9, 2021 at 10:29 pm
- The topic ‘What does it mean by ‘Warning: zone of type interior found between different solids!’?’ is closed to new replies.
5729
