December 17, 2021 at 6:16 am
mandeep_shetty
SubscriberI have created (in ICEM itself) 2 squares connected by a curve in the middle (Which is red in color after the topology is built).
i) Are these 2 square surfaces separate 'Patches'?
I meshed them with Patche Dependent and Patch Independent methods. Both methods respected the middle curve separating the 2 squares and gave a conformal mesh.
I deleted (not permanently) the middle curve ( so its dormant) and again meshed with Patche Dependent and Patch Independent methods. This time both methods did not respect the middle dormant curve. I had expected the Patch Dependendent method to respect the middle dormant curve since I thought the 2 squares are separate patches. But that was not the case.
So my question is what are 'Patches' and how are they different from 'surfaces'.
December 17, 2021 at 5:27 pmRK
Ansys EmployeeHello,
Just to confirm, you are using ICEM right?
December 17, 2021 at 5:34 pmmandeep_shetty
SubscriberYes I am using ICEM. But the question is general since patch-dependent and independent methods are used in other Ansys products too.
December 18, 2021 at 4:42 ammandeep_shetty
SubscriberI am shifting this to preprocessing page.
Viewing 3 reply threads- The topic ‘What are surface “Patches”’ is closed to new replies.
5869
1306
