October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeFollowing are our suggestions for increasing the speed:
1. Presence of any nonlinearities in the model. These would include plasticity, hyperelasticity, large deflection, contact of any type other than bonded other nonlinear element types (combin37, combin39, prets179, etc). The presence of nonlinearities can significantly increase the solution time. So reducing or removing the nonlinearities will affect the solution time the most.
2. Next is reducing the model size. This is usually the number of nodes but if there are constraint equations (CEs) in the model, then reducing the number of CE's will speed it up. A point mass element attached to a surface that contains a lot of nodes creates a lot of CEs.
3. Writing the minimum result data and at the minimum number of time points will speed up the solve time.
4. Reducing the number of substeps and load steps will speed up the solution but unless you have put in a very small time step or other setting that forces many solutions this will likely not affect the solution time.
5. Increase the maximum number of utilized cores under the solve process settings.
October 5, 2017 at 11:39 am
pgl
Ansys EmployeeWhat are some suggestions to increase the analysis speed?
- The topic ‘What are some suggestions to increase the analysis speed?’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
