Wet steam modelling in CFX OR FLUENT
    • gau1am
      Sir can I model the wet steam of 20% water droplet and 80% of dry steam in the pipe of inlet pressure 17bar and outlet pressure of 2bar. If it can be done then which material type is used in CFX?, even I checked in CFX about IAWPS-97 but it does not work for me because it has its own set of pressure values.nIf it can be done in Fluent then how it can be modelled please help me I got stuck for 2 months and not getting how to get it.nKindly please help me.n
    • Surya Deb
      Hello, nFluent can model Wet Steam. Please have a look at this link for more information on the setup procedure. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/flu_ug/flu_ug_sec_wet_steam_using.htmlnAlso, if you want, you can create your own user defined wet steam properties. Please have a look at this link. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/flu_ug/flu_ug_sec_wet_steam_udf.htmlnRegards,nSDn
  • The topic ‘Wet steam modelling in CFX OR FLUENT’ is closed to new replies.
