December 3, 2024 at 12:06 pm
saransh.verma2810
SubscriberI want to simulate TIG welding in ansys using moving heat source and element birth and death method and using convection and radiation as thermal boundary conditions.
I am getting error each time
Please Help Me.
Error and pictures
*** ERROR *** CP = 7.922 TIME= 17:32:12
The value of TEMP at node 2486 is 9199447.37. It is greater than the
current limit of 1000000 (which can be reset on the NCNV command).
This generally indicates that there are no temperature constraints or
convections applied. -
January 3, 2025 at 12:23 pm
Ashish Khemka
Forum ModeratorHi,
The error indicated here indicates that heat us not getting dissipated from the body containing node 2486. Can you please share the images showing how you have applied the boundary conditions? Do you have a convection boundary condition defined in the model?
Ashish Khemka
5799
