May 31, 2024 at 6:46 am
vinay.dv
SubscriberWe wanted to check the life of the weld due to vibration velocity and additional loads sepaerately.
How to evaluete the same in ansys?
July 5, 2024 at 3:29 pm
danielshaw
Ansys EmployeeMechanical does not provide an automated method for assessing weld fatigue. If you have access to Ansys nCode DesignLife, you consider using it.
August 2, 2024 at 2:12 pm
vinay.dv
SubscriberHello Daniel,
  We have the acess to ncode, could you just provided us some usefull example files and related documents it will be very helpful
August 2, 2024 at 2:51 pm
danielshaw
Ansys EmployeeThere is at least one weld fatigue example in the Ansys nCode DeisgnLife Worked Examples.
There is also a weld fatigue training course available on the Ansys Learning Hub.
If you have an Enterprise license for 24R1 or 24R2, I recommend that you try using the Ansys nCode DesignLife Add-On for weld fatigue.
- The topic ‘Weld life calclulation in ANSYS mechanical.’ is closed to new replies.
5654
1890
1414
1303
