3D Design
3D Design
WELD in SpaceClaim
    • Lukas Janicek
      lately I have a problem with the Weld function (Prepare - Weld). I can't create a weld and the second time I try to create a weld, SpaceClaim crashes.
      Do you know about this problem or do you know the solution?
      Thank you and have a nice day.
      Kind regards
      Lukas
    • Atharv Joshi
      Hi Lukas,
      Which version of SpaceClaim are you using?
      Can you attach the screenshot demonstrating the weld you are creating?
      I will try this at my end and will let you know.
      Thanks and Regards
      Atharv
    • Lukas Janicek
      Hi Atharv,
      I am sending the file and video using the link below.
      File: https://www.dropbox.com/scl/fi/3g2s1ttlp8ccyg6c87m3t/weld.scdoc?rlkey=z5msy4awgjy55ldrj673w5dzm&st=bayg45qs&dl=1
      Video: https://www.dropbox.com/scl/fi/pvbln2slure2pzs7w8m94/weld.mp4?rlkey=xc8ie3kfqqoru096cjdj2zlz0&st=iqj124q8&dl=1
      Thank you and regards,
      Lukas
    • Atharv Joshi
      Hi Lukas,
      I have shared a transfer link shared with you.
      Can you please attach the file, video over it?
      Thanks and Regards
      Atharv
    • Appo Veini
      It still doesn't work in SpaceClaim 2024 R2, crashes.
    • Atharv Joshi
      Hi Appo,Lucas
      You can create a spot weld between 2 solids. Weld surface is not possible between 2 solids.
      You can weld surface bodies to other surface bodies or to solid faces.
      Try to create mid-surface first and then select the weld tool.
      Thanks and Regards
      Atharv
Viewing 5 reply threads
  • The topic ‘WELD in SpaceClaim’ is closed to new replies.
