July 27, 2021 at 12:52 am
rldlghdh
SubscriberHello, I have a question about core loss measurement.
I applied the square wave voltage to the wire and measured the core loss from transformer,
but it shows really weird core loss wave forms.
I also changed the time step, but it show same result.
The red one from following is the core loss
July 27, 2021 at 12:52 amJuly 28, 2021 at 3:01 pmHDLI
Maxwell uses dynamic core loss model and method to calculate the core loss, and there is an reference "a dynamic core loss model for soft ferromagnetic and power ferrite materials in transient finite element analysis", D.Lin, etc.
With high increase of excitation or flux density, the core loss had a high value in this calculation. The above results make sense for me so far because of the excitation with harmonics. Here is some information for it.
1). Try to use smooth BH curve.
2). If using current source, the current excitation should be smooth and reasonable in physics. It is no special requirement for the voltage source.
Thanks.
HDLI
Viewing 2 reply threads- The topic ‘Weird Core loss’ is closed to new replies.
5814
