February 21, 2023 at 5:27 am
Shashank Gupta
SubscriberHello Sir,
I am following the curved waveguide taper example " https://optics.ansys.com/hc/en-us/articles/360042799713-Curved-waveguide-taper-varFDTD-and-FDTD- " for taper design for my material.
The gaussian source defined in the exampler uses 'use thin lens' method in the beam option setting. I am unable to understand how the beam option parameters (NA, lens diameter, beam diameter, etc) is defined ?
I think it depends on the effective refractive index. If so then how to decide these values for different refractive index (neff for my material is 1.91).
Also, boundary condition in varFDTD uses 'uniaxial anisotropic PML' setting. How to define these parameters?
Thanks
November 23, 2023 at 11:51 pm
Dev
Ansys EmployeeHello, this post is duplicate.
Please refer to the respose of original post:Â waveguide taper design varFDTD simulation (ansys.com)
Thanks and regards
Devika
- The topic ‘waveguide taper design varFDTD simulation-Duplicate’ is closed to new replies.
4502
1494
1376
1209
