September 24, 2021 at 3:15 pm
dharmatejap
SubscriberHi,
How to set up waveport correctly for differential CPW? (Terminal solution)
I have total four conductors with outer two as GND and inner two as signal traces for differential signalling.
I selected two GND as reference when setting waveport. In the port set up dialog box, there is a Note about connecting the multiple reference conductors. I am not able to understand how to "connect multiple reference conductors in the plane of port".
I tried CPW example set up to my differential CPW setup, but I am getting warning messages that more conductors than terminals can affect the results.
Please help me resolve these issues.
September 29, 2021 at 12:13 pmAncS
Ansys EmployeeSeptember 30, 2021 at 3:01 pmSeptember 30, 2021 at 5:33 pmtyler.reid
SubscriberMake sure the outer edge of your waveport makes contact with the CPW grounds. For GSSG like you have, the ports should be reduced to contact the two outer grounds.
September 30, 2021 at 6:04 pmdharmatejap
I did that but it didn't help in removing the warning messages.
October 1, 2021 at 1:46 amAndyJP
Subscriberok. i missed what you mean at first
October 4, 2021 at 5:13 pmPraneeth
May I know why you are using two separate traces for ground.
Please make sure that the both ground conductors are touching each other.
All the very best.
October 4, 2021 at 5:33 pmdharmatejap
My set up is GSSG.
I do want to connect two grounds but in wave port scenario how do I do that?
Is it possible with any boundary conditions on the face of waveports?
I tried connecting a metal across but that doesn't seem to work.
October 5, 2021 at 12:20 amAndyJP
SubscriberProbably, he wants o see how out of phase excitation works on "coplanar". I guess, it is a bad idea and can not be called a coplanar, rather just two slotlines (fed by a hybrid maybe?). So first, you need a model of a hybrid coupler.
That is not a coplanar line, first of all. But anyway, it is not my project, and everyone are free to try and see.
// in coplanar, the mode itself is driven by the central conductor. So it is not just two slots, but a hot coax wire with the jacket unfolded into two infinite planes connected together somewhere beyond physically, or virtually, it does not matter. therefore, in the wave port, you define just one integration line starting from only one hot strip. The only possible wave solution will automatically produce the opposite field vector in the paired slot. Or it may produce a microstrip mode in the solved model of the ground backed cpw, if matching is bad.
October 5, 2021 at 6:20 amPraneeth
Please share the snapshot of how you have connected the ground traces as mentioned in this post.
Best regards.
October 14, 2021 at 2:34 pmtyler.reid
SubscriberThe outer edge of the port is treated as conductive for setting up the fields, so if the port touches both then the two outer metal strips would be at the same potential. In my experience a grounded coplanar waveguide structure with ground layer under the traces is more common, in which case there should be a metal ground layer underneath. The two ground lines are then connected to the ground plane with vias along their length. If there's nothing connecting them, then there is nothing to keep them at the same voltage.
Viewing 10 reply threads- The topic ‘Wave port for differential CPW’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4177
1487
1363
1194
