December 7, 2022 at 12:30 pm
December 7, 2022 at 2:29 pm
Mike Pettit
Ansys EmployeeHello,
This is caused by a bug which started affecting all released versions of Aqwa on 01/01/2022. The possible solutions are:
- Update your Ansys installation to 2022 R1 Service Pack 1 or 2022 R2; or
- Re-run your Aqwa analysis with 'Generate Wave Grid Pressures' option (in Aqwa Workbench editor), or with 'SEAG' data record (in Aqwa input file); or
- If you have one, copy any old PAG file into your analysis directory and AqwaGS should automatically recreate it (this may take several minutes, during which time AqwaGS will be unresponsive).
I hope this helps.
Mike
December 7, 2022 at 4:24 pm
K. H.
SubscriberUsing the SEAG data record worked, thank you!
December 7, 2022 at 5:36 pm
Mike Pettit
Ansys EmployeeGreat, happy to help!
- The topic ‘Wave contour plot in Aqwa GS’ is closed to new replies.
1510
1386
1209
