May 27, 2023 at 11:30 am
ermias tesema
Subscribermodeling of solar cabinet dryer integrated with rectangular baffled collector for mango slices dryer , to model water vapor transport in the drying chamber source terms must be applied to the porous mango slices,we have the property of mango as well as the boundary conditions required, the problem is the source term equations needed to insert in the expression part, can you give me the final and the exact equations for modeling water vapor transport in ANSYS cfx with example.
June 1, 2023 at 9:29 am
C N
Ansys EmployeeHello Ermias,
I recommend you to check this tutorial in user guide link where there is water stream jet case in this case there is a procedure to set up the water vapour transport . Please change the values with your data and you should be able to perform your simulation. If you need further assitance please reach out .
Chapter 29: Steam Jet (ansys.com)
Refer 29.4.2 importing steam jet (ccl)
I hope this solves your problem.
Thanks
Chaitanya Natraj
- The topic ‘water vapor transport in ansys cfx porous domain (product)’ is closed to new replies.
5669
1890
1419
1304
