January 23, 2026 at 12:15 pm
Neeraj.Kewat
SubscriberHi,
I am working on a Harmonic response analysis and need Water Properties for analysis.
Watel available in General materials, doen have sufficient properties.
January 23, 2026 at 12:49 pm
ErKo
Ansys EmployeeÂ
Hi
I do not see Water in Eng. Data and General Materials Library.
Second of all what do you want to do with Water in Harmonic Response – Air and Water properties are often use for acoustic media or EMAG not for linear elasticty.
If you want to do a vibro-acoustic analysis say to predict the fluid added mass effect, then define a material with density speed of sound and assign to a acoustic region.
There is a course in ALH on thisÂ
Describe more what you are doing and why you need water (what are suffecient proerties).
Erik
January 23, 2026 at 5:27 pm
Neeraj.Kewat
SubscriberHi,
Thank for reply,
Yes, I need to work on a vibro-acoustic analysis.
Boundry condition - tank filled with water, there is a component inside the tank which excite vibration. I have to study these vibration effect on tank plate.
January 26, 2026 at 8:01 am
ErKo
Ansys EmployeeHi
There is a course in ALH on this mechanical acoustics.Also some videos showning. Use water liquid or define your own wih speed od sound and density only.
https://www.youtube.com/watch?v=Kq3iuYK52gc
If you get suck please open up a support ticket ACSS and we will help.Erik
5834
