July 11, 2024 at 12:40 pm
Simo
SubscriberGood morning,Â
I am trying to model a capillary water absorption in a solid porous media, such as construction materials, by Ansys Fluent. I did not understand how to insert the two phase fluids (water and air), and to implement the (concrete) like material in the mean that the water will come through. My version is the one for student (Free Version), and the mean is a simple cube 2D 150 mm x 150 mm. Thanks for your attention.Â
Best regards,Â
Simone.
July 11, 2024 at 2:15 pm
Forum ModeratorHave a look at the Corey model in Fluent's porous media; turn on the Eulerian Multiphase Model. However, you may find as it's almost a diffusion process that there's a hand calculation that may tell you what you need to know.Â
July 11, 2024 at 3:32 pm
Simo
SubscriberGood evening,Â
Thanks for your answer. Where may i find the explanation of Corey model? About that, on internet i could not have found nothing. Yes, what I am trying to look in for is the rising of the wet front.Â
July 11, 2024 at 3:51 pm
Forum ModeratorI'd start with the documentation (User's Guide > Solver > Cell Zones > Porous Media). Click on Help in the Fluent Solver to bypass the security steps.Â
July 18, 2024 at 8:02 am
Simo
Yes, i looked for the model in the user guide, and I've assimilated my concrete sample like a packed bed by my experimental data. The fluid still rising a lots, and seems there's no materials in porous media. I calculate the both coefficients alpha (and then 1/alpha) and C2 and i put them in the porous schedule. Maybe the problem is the hydrostatic pressure i give: to simulate that i put a slow velocity to 0.001, could be that correct? My sample is just in contact with water. No pressure applied.Â
Thanks for the answer.Â
Simone.Â
July 19, 2024 at 12:22 pm
Forum ModeratorYou need water to beable to flow, and have some means of getting it into the domain. So, a block sat in liquid may be a good start, possibly with an open channel bc to replenish the water.Â
July 19, 2024 at 12:31 pm
Simo
Subscriberhttps://www.youtube.com/watch?v=6DREG-OpB5k this example could be suitable with mine?Â
July 19, 2024 at 12:48 pm
Forum ModeratorLooks reasonable from a quick skim - try it and see!Â
July 23, 2024 at 8:47 am
Simo
Subscriber -
July 23, 2024 at 1:18 pm
Forum ModeratorWhat's the mesh resolution like?Â
July 23, 2024 at 1:32 pm
Simo
Subscriber0.0005 m. Otherwise, if i do not consider brooks and corey model, the water front dont rise again but at least it curves beyond the sides.
July 25, 2024 at 10:08 am
Simo
SubscriberHello,Â
I have tried instead to make just the sample and to set the water front starting from 5mm. I changed the initial theory model to Brooks and Corey and capillary pressure by Leverette-J by setting Leverette angle to 30°. Actually it does not match with my experimental data, but works. Otherwise, if i set Brooks corey also for capillary pressure, the front does not rise. It keeps still.Â
Best regards,Â
Simone.Â
July 25, 2024 at 1:09 pm
Forum ModeratorIt's an extra resistance, are we missing something in the model?
July 25, 2024 at 3:25 pm
Simo
SubscriberI set as upper condition wall (outflow is not allowed for Eurelian flows), and I set two-phases and i modeled air as same as the water. Is that correct? Upon I have found packed bed values C2 and alpha, I inserted that into both air and water phases' schedule. Should air have the same values than water?
July 25, 2024 at 4:25 pm
Forum ModeratorWall? If it's a wall where does the gas go? The packed bed coefficients (Ergun Equation) are covered in the User's Guide, and doesn't contain fluid properties https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/flu_ug/flu_ug_bcs_sec_cell_zones.html%23flu_ug_using_porous_media
July 26, 2024 at 7:09 am
Simo
Yes, I followed the User's guide of packed bed and i calculated from my experimental data alpha -> 1/alpha and C2. And i have inserted that as viscous resistance and intertial resistance, respectively. That for the phase water and air too. should the same values been inserted for air?
July 29, 2024 at 10:47 am
Forum ModeratorYes - as there isn't any effect for density & viscosity in the documentation. If you were modelling a filter with Eulerian it's a different answer!Â
August 12, 2024 at 9:13 am
Simo
SubscriberYes, I am modeling with an Eulerian model. What should it change?
August 14, 2024 at 2:59 pm
Simo
SubscriberI tried to make different analyses with others materials i got in the lab, and Eulerian model does not work. The front rise equal for every materials I proposed. Nonetheless, Volume of Fluid (multi-phase) contrary works quiet good and reach convergence with my experimental data. How is that possible? Am i missed some values in settings?Â
August 14, 2024 at 3:36 pm
Forum ModeratorVOF will rise based on the wall, Eulerian multifluid VOF should also respect the porous media. Checking with a colleague.Â
August 15, 2024 at 7:58 am
Simo
SubscriberI checked a little bit and seemed that Brooks and Corey does not fit with my work. A few examples on YB explained well how to implement Brooks and Corey but far rising in a straw or low section rise where the angle of contact is predominant. Is there any forum page open for a case like that?
Regards.Â
August 15, 2024 at 9:20 am
Forum ModeratorPossibly not, having double checked you may need a UDF.Â
September 2, 2024 at 4:15 pm
Simo
SubscriberHi,Â
How can I see Help user guide?Â
I did not solve any problem, yet. In my case, concrete is compared with other ligher material, but as soon as the Dp is higher than others, the permeability is higher, and then, the water front does rise more than ligher material (made by finer particles). How can i solve that problem? I checked in a internet guide I have found, but no idea what it missing. Is there a guide into the forum I may take advices from?Â
September 9, 2024 at 10:00 am
Forum ModeratorIf you click on Help in the solver you'll get the "licenced" version, or use https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/main_page.html?hl=f as we've put most of the documentation outside the security firewall.Â
- The topic ‘Water Absorption in Porous Media – Ansys Fluent’ is closed to new replies.
5694
1891
1419
