August 27, 2018 at 1:26 pm
Aya.hassan
SubscriberI am using the External Data utility in fluid structure interaction analysis. The fluid is solved and output pressure then it is imported into structure. The pressure is imported and the model is solved but I have this warning:
The program controlled pinball grew more than 10% of the source point bounding box maximum length
What does it mean and how can I overcome this warning?
August 28, 2018 at 3:05 am
Bhargava Sista
Ansys EmployeeAbove warning message appears if program controlled pinball is greater than the source points bounding box. This warning message usually shows up in the case of trying to map results from a fine mesh to a coarse mesh using the Triangulation technique. The search algorithm would start by a program controlled pin ball size, but since the mesh is coarse, this size may be increased to find the closest nodes.Â
Specify a pinball larger than the gap between the source and target nodes.
- The topic ‘Warning while using the External Data utility’ is closed to new replies.
2999
970
857
761
599
