Warning: The result file cannot be opened, Solver cannot write results
January 16, 2021 at 10:22 am
Faruk_Smed
SubscriberHello
I have an issue with static structural calc. As long I work on unsaved project everting is OK, solver is finishing and I can evaluate stress and deformations.
Problem start after I save workbench project and change something in my setup (eg. add a additional force). After I re-run my solver everything is OK until very end, when solver is finish and need to write results. Then Iget error message:
Error: An error occurred when the post processor attempted to load a specific result. Please review all messages.
Warning: Current result file may not contain requested result data . Please clear the solution and solve again.
Warning: The result file cannot be opened.
January 18, 2021 at 1:47 pmRahul Kumbhar
Ansys EmployeeI couldn't guess what can cause this problem. Since there is green check mark on 'Solution Information' I think it is solved successfully. Try delete the results already added and save and insert new result.nJanuary 19, 2021 at 9:37 pmFaruk_Smed
Subscriberhinnproblem solved. Scratch folder was missing. The one where solver write while it solves. After solution is done, content of it transfers to workbench project file location.nit was needed to re-map from mechanical module to C:\ScratchnApril 3, 2021 at 8:52 amemanuelberil
Subscriberhiproblem solved. Scratch folder was missing. The one where solver write while it solves. After solution is done, content of it transfers to workbench project file location.it was needed to re-map from mechanical module to C:\Scratch/forum/discussion/comment/103719#Comment_103719
Mr. Faruk, could you explain how exactly you managed to solve this problem? I have the same situation occurring in my analysis and this is leaving my work far behind. Thanks in advance.nJanuary 30, 2023 at 5:07 pmAtli Tobiasson
SubscriberI suggest checking if your workbench project is stored in cloud storage. This can be a potential issue as projects must be stored locally to obtain a solution.
April 24, 2023 at 9:20 pmAmit M Deshpande
SubscriberI am facing this issue for explicit dynamics alone. Static structural analysis ran perfectly well. Could you please elaborate on how this issue was resolved?
June 14, 2023 at 7:47 amNadiia Kopiika
SubscriberCould you please explain, how you managed to resolve this problem (after solution is done, content of it transfers to workbench project file location.it was needed to re-map from mechanical module to C:\Scratch). How to re-map from mechanical module to C:\Scratch ?
Viewing 6 reply threads- The topic ‘Warning: The result file cannot be opened, Solver cannot write results’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3912
1414
1256
1118
1015
