Warning “The requested S data is not available. The ETABLE command is isgnored.”
    • Simone Del Nero
      Hi everyone,
      I'm performing a static structural analysis and I'd like to plot the stress. I tried to extrapolate this information initially from the section "Plot results" in the GUI and then creating an element table. I followed a suggestion found in this forum, that is, using the option "Use Shared-Memory Parallel (SMP)" instead of "Use Distributed Computing (DMP)".  However, I'm able to plot the deformation.
      Can someone help me and guide me?
      Thank you!!!
    • ashish.khemka
  • The topic ‘Warning “The requested S data is not available. The ETABLE command is isgnored.”’ is closed to new replies.
