Warning: No Cyclic constraint equations are not created for Thermal DOF’s(Temp)
April 14, 2025 at 5:39 am
loiteringfish
SubscriberI tried to create a Steady-State Thermal with Pre-Meshed Cyclic Region setting, but I found that I have no choice to operate this model with REAL CYCLIC. When I run this model, it can be sloved but the answer in two cyclic boundary regions are not matched with wach other, and there is a warning which writes [No Cyclic constraint equations are not created for Thermal DOF's(Temp)].
I wonderd how can I calculate Thermal with Cyclic models correctly ( which means the cyclic regions are matched with each other ) , or it's not availble from the point of software functions? I found the explanation about Thermal constraint in Ansys website which said that [Cyclic symmetry solution does not work for elements that have thermal and hydrostatic pressure degrees of freedom.], you can see that on the pic and the link. https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/ans_cycsym/advcyclmnt.html
April 14, 2025 at 5:42 am
loiteringfish
SubscriberPlease help me, or communication is also welcomed!
April 16, 2025 at 2:42 am
Huadong Sun
Ansys EmployeeAccording to the help documentation, Cyclic Region and Pre-Meshed Cyclic Region are supported for steady-state thermal analyses. However, in the post-processing stage, only the current individual sector's results can be viewed — the full model results are not available.
If viewing the entire model’s results in post-processing is required, the full model must be built in the pre-processing stage, instead of using cyclic symmetry boundary conditions.
https://ansyshelp.ansys.com/public/account/secured?returnurl=//Views/Secured/corp/v251/en/wb_sim/ds_cyclic_sym_considerations.html
- 您必须登录才能回复此主题。
2848
970
851
599
591
