“Warning: cannot modify NASA9 piecewise polynomials for air.”
    • jal139
       When I attempt to use the two-temperature model, I encounter the following warning (see the attached image):
      "Warning: cannot modify NASA9 piecewise polynomials for air."
      Could anyone please advise on how to address this warning?
    • Essence
      Which version are you using? Ensure you have 2T model as well as cfd_hsf license to run the hypersonic cases. Did you try to change the coefficients of NASA 9-coeffs?
    • 022120216
      Hello, I encountered the same issue while setting up in Fluent 2022R1.
      • Essence
        Could you please open a new Forum thread? We would be happy to help you out there. Thanks.
