April 25, 2024 at 11:39 am
Manish Patel
SubscriberI am doing a pool boiling simulation where heatedWall has constant wall temperature boundary condition.Â
Now, I want to get Total wall heat flux value at heatedWall. How can I do that in ANSYS Fluent?Â
More specificaly my question is, in surface integral, Do I need to do the area weighted average, integral, sum, area etc. or something else?Â
April 25, 2024 at 2:24 pm
Forum ModeratorI'd look in the Reports>Fluxes panel.Â
April 26, 2024 at 6:56 am
Manish Patel
SubscriberReports>Fluxes gives total heat transfer rate (W). Which I divided by the area and I found that it is same value as reported by surface integral>Area averaged>Total Heat Flux. So, it's correct method right? Just want to confirm.Â
April 26, 2024 at 8:51 am
Forum ModeratorAs in I'd take the Flux Report value as that's returned directly from the solver, and is available as you're reporting on a mesh surface.Â
- The topic ‘Wall heat flux from constant wall temperature boundary condition?’ is closed to new replies.
6149
