May 31, 2024 at 1:55 pm
javdijaj
SubscriberDear,
I am meshing a furnace on Ansys R2022R2 Fluent Meshing.
Everything goes well till the moment I save the mesh and open it in Fluent Solutions for the set-up.
One of the walls (with a Named Selection in SpaceClaim) is missing in the set-up when I read the mesh.
The wall is defined with the right name as all the other walls in Fluent Meshing.Â
However, I am missing one even though all the others are in the case once I open it in Solutions.
Could have not been a problem but I have to apply a specific BC on that missing wall for my application.
Has anyone had that issue before ? If yes, do you know how to get it back or add it directly in Fluent Solutions ?
Thank you in advance for your response.
J.Avdijaj -
June 3, 2024 at 1:23 pm
Forum ModeratorIt depends on why it's not present. If you look in the list of boundary conditions has it been reassigned to (for example) a velocity inlet?Â
- The topic ‘Wall disparition from Fluent Meshing to Solutions’ is closed to new replies.
- affinity not set
4387
1494
1375
1203
