Preprocessing
Preprocessing
VolumeFillControl of Poly-hexcore mesh generation?
    • l454552485
      Dear all,
      I'm using Fluent 19.2 poly-hexcore module for mesh generation.
      The question is in the poly-hexcore mesh generation module there is no direct option for volume mesh control.  So I am wondering is there anything I can do to control the max cell length?
      Thanks!
      PS. During the poly-hexcore mesh generation process, there is a hint from the console panel likes:
      VolumeFillControls: .....(HexMaxCellLength : xxx)......
      If you're using the new Clean CAD workflow there's an option in the volume mesh section.
    • l454552485
      Thanks a lot!
    • l454552485
      Sorry to bother you, but where can I find the Clean CAD workflow?
    • Keyur Kanade
      max cell length is available for poly hexcore.
    • l454552485
      I think you mean "Min Cell Length" ?
      When you open Fluent Meshing click on the Workflow and then Clean CAD Workflow. Do not import anything first: the approach has been added to simplify using Fluent Meshing for many users but allow extra bits to be added by advanced users.
    • l454552485
      Thanks for the reply. But I couldn't find the Clean CAD Workflow and there only Watertight Workflow option. Is that a beta feature?
      By the way, my Fluent version is 19.2.0.
Viewing 7 reply threads
  • The topic ‘VolumeFillControl of Poly-hexcore mesh generation?’ is closed to new replies.
