TAGGED: fluent, fluent-mesh, mesh, meshing, surface-mesh, surface-meshing
November 16, 2023 at 4:44 am
Elijah Pruett
SubscriberHello, I am new to Ansys and Fluent software. I am working on a project for school and I need to create a volume mesh. The problem is that my school only has access to Fluent 2020 R1 and I do not have access to the geometry file, just the surface mesh. How can I create a volume mesh from a surface mesh without the geometry file? I understand that newer versions of Fluent have an option in workflow>watertight geometry>import geometry>file format>mesh but this doesn't seem to be the case in the 2020 versionÂ
Thanks
November 16, 2023 at 2:01 pm
Federico
Ansys EmployeeWhat is the format of the surface mesh file? You may be able to import it into SpaceClaim and work with a faceted geometry as your model.Â
November 16, 2023 at 2:27 pm
Elijah Pruett
SubscriberIt is a .msh fileÂ
November 16, 2023 at 2:34 pm
Federico
Ansys EmployeeIf you go through the link provided, you'll find that .msh files can be read in SpaceClaim.
November 16, 2023 at 6:45 pm
Elijah Pruett
SubscriberThank you for your response, however I cannot seem to access that page without a customer account which I do not have due to me being a studentÂ
- The topic ‘Volume mesh generation with surface mesh’ is closed to new replies.
