August 28, 2023 at 6:25 am
Prashant Jha
SubscriberHello all, I am tring to do simulation of multiphase flow and have defined the phases. My phases are one on top of other, but when i preview my phase distribution before starting the simulation then between two phases no sharp interface is there. I have attached the image for reference. Any clue on why this is happening and how to rectify it.
August 28, 2023 at 1:59 pm
SRP
Ansys EmployeeHi,
Try to patch phase by creating appropriate region or you can create separate zone to patch regions.
Thank you.
August 28, 2023 at 2:47 pm
Prashant Jha
Subscriberi think i have done so. I first marked the three regions in the cell registers options and then patched the phases with their respective regions.Â
August 28, 2023 at 6:36 pm
SRP
Ansys EmployeeHi,Â
Can you try to plot contours and share here for single phase individually just to verify how it is displayed?
Thank you.
August 28, 2023 at 7:29 pm
August 29, 2023 at 1:14 pm
SRP
Ansys EmployeeHi,
Can you please try to replot the contours keeping nodes values off?Â
And can you share the patching setting that you have incorporated?
Thank you.
August 29, 2023 at 5:02 pm
Prashant Jha
Subscriberyes, now i can see the problem, when i turned off the node values.
For patching, in the patch window, for phase 2, i am giving value 1 to region of phase 2 and value 0 to regions of phases 1 and 3. Similarly, for phase 3, i am giving value 1 to region of phase 3 and value 0 to regions of phases 1 and 2.
August 30, 2023 at 5:15 am
SRP
Ansys EmployeeHi,
Great. Be careful during patching as only the secondary phase volume fraction is solved in case of VOF. Primary phase volume fraction is deduced from secondary phase volume fraction.
Thank you.
August 30, 2023 at 5:46 am
Prashant Jha
Subscriberok so the values which i am giving for patching are correct??
August 30, 2023 at 5:53 am
SRP
Ansys EmployeeHi,
Looks good. Try running to get your desired results and check ansys user's guide: 25.3. Setting Up the VOF Model (ansys.com)
And theory manual for more details: 14.3. Volume of Fluid (VOF) Model Theory (ansys.com)
Thank you.
- The topic ‘volume fraction method’ is closed to new replies.
5979
1307
