June 1, 2024 at 4:59 pm
nicolino.ruotolo
SubscriberPreparing the body for volume extraction in order to run a fluid simulation, at the end of the selection of inlet and outlet and the seed face, according to several tutorial, I selected the "preview inside faces" and the result message is : "Edges are not on the same body". How could I sort this out?
Infact, taking a look to the physics it seems the whole body involved as per following pic:
Any suggestion?
Thank you,
Nicolino
June 3, 2024 at 5:09 am
Keyur Kanade
Ansys EmployeePlease check geometry in SpaceClaim/Discovery.Â
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.Â
If geometry has any errors, please modify/recreate geometry at those places.ÂÂ
You can find general procedure for fluid volume extraction in following video.
https://www.youtube.com/watch?v=Jp8btI0PCyUÂÂ
Another reason is having some tangential contacts at some circular surfaces. Please make sure that bodies are intersecting instead of just touching each other.
Sometimes bodies are in contact only at some edges. At this point volume extraction may fail. In this case as well please make sure that bodies are intersecting each other.
During volume extraction some boolean operations are done in the background. If those boolean operations fail then volume extraction fails. In this case please check if you can use "Combine" command to "Merge" all solid volumes one by one. Please check if any volume is giving any problem.Â
If you have only handful bodies not part of fluid volume, please check if you can use "Combine" command to subtract required bodies from fluid volume.
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- The topic ‘Volume extract Body’ is closed to new replies.
5649
1885
1404
1303
.png)
