June 25, 2021 at 2:43 pm
hani.sadek_i
SubscriberHello,
I am simulating a coil in Ansys maxwell and I am applying voltage excitation.
Are the resistance and inductance shown below, the source impedances ? or the resistance and inductance of the coil?
June 26, 2021 at 12:20 pmJune 28, 2021 at 6:23 pmhani.sadek_i
SubscriberThank you!
Viewing 2 reply threads- The topic ‘Voltage excitation in Maxwell’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4067
1487
