TAGGED: #Modal_Analysis, 3d-maxwell-simulation, resistance, simulation
January 26, 2024 at 4:21 pm
Sidinei Ribiscki
SubscriberHello,
So, I need to get the resistance of this sensor show in the image bellow. It's a multilayer structure of different materials. What type of simulation do I have to do? And whats steps do I have to take?
After obtaining the resistance value I'll create a magnetic field to see the decrease in resistance due to materials properties. Fyi just started with maxwell. -
January 30, 2024 at 4:32 pm
DELI
Ansys EmployeeIn order to answer your question, we need more information: What is the excitation, AC or DC? How does the excitation apply on this sensor?-
February 10, 2024 at 3:29 am
Sidinei Ribiscki
SubscriberI'm simulating a walk-through metal detector, as in the image bellow. I need to detect the values of the magnetic field when there's a metal going through the portal and when there is nothing passing through it. There is a coil that generates a primary field, and the sensor is a Giant Magneto Resistance Sensor, that changes the resistance with different magnetic fields. So far I wasn't able to even find the passive resistance of the sensor without a field. Can someone help?
February 10, 2024 at 3:30 am
Sidinei Ribiscki
- The topic ‘Voltage drop or resistance of multilayer structure of GMR sensor’ is closed to new replies.
4989
1665
1386
1242
