void fraction term in porous media
    • Honig
      Hello everyone,
      I hope you are well.
      Currently, I am studying the flow of oil through porous media. For that, input about the inertial resistance factor C_2 is needed. The ANSYS help provides an equation based on the Ergun equation that allows me to find a value for C_2 (see attached).
      Epsilon is described as the "void fraction, defined as the volume of voids divided by the volume of the packed bed region".
      As far as I understood it, it is the "empty" volume in the porous region divided by the entire volume of the porous region, so basically the porosity, which I calculated earlier in a different step.
      Is that assumption correct or am I missing something?
      Thanks for your input!
      Best regards
    • DrAmine
      That is how a packed bed can be modeled: is you porous media similar to a packed bed? If yes you might use the formula to estimate the coefficients, if not you require data to make that estimate.
    • Honig
      Hello Amine,
      thank you for your reply.
      My porous media resembles a flat sheet of nonwoven material, which only is the middle part of the entire simulated region (a simple cylinder). If that does not count as a packed bed for the flat porous region, the data I'd need for other ways to calculate C_2 is not available in my case.
      Can/could the the inertial resistance be omitted for slow laminar flows?
      Best regards
    • DrAmine
      Yes it can be omitted and you focus one the viscous term.
  • The topic ‘void fraction term in porous media’ is closed to new replies.
