December 26, 2023 at 10:30 am
kuibo wu
SubscriberHello everyone, when I was preparing to use udf to adjust the lump conversion, the example given in the manual reported an error when compiling: fatal error C1083. How do I fix this?
With best wishes!
January 2, 2024 at 4:02 pm
Forum ModeratorPlease can you post all of the errors? Did you check the copied .c file for random white space characters?
January 6, 2024 at 3:44 pm
kuibo wu
SubscriberThank you for your reply!The error code is as follows:
D:\Program Files (x86)\ANSYS Inc\v212\fluent\ntbin\clang\10\Include\10.0.18362.0\shared\basetsd.h(322,11) : warning: cast to 'void * __ptr32' from smaller integer type 'unsigned long' [-Wint-to-void-pointer-cast]
return((void * POINTER_32) (unsigned long) (ULONG_PTR) p);
lump.c(2,9) : fatal error: 'lump_detect.h' file not found
#include "lump_detect.h"
1 warning and 4 errors generated.
scons: *** [lump.obj] Error 1
scons: building terminated because of errors.
Done.
January 8, 2024 at 9:57 am
Forum Moderator2021R2 is an older build, was the code you used for that version? There have been a few changes in the model so it's possible some of the calls are for 2022Rx and onwards.
- The topic ‘VOF to DPM: A question about head file of “lump_detect.h”’ is closed to new replies.
5694
1891
1419
