    • Keshav Sharma
      I want to extract an injection file from my vof simulation to run DPM seperatly using.inj file. Can anyone help me how to do that?
      I think it's all covered here,   https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/flu_ug/flu_ug_sec_mphase_using_steps_vof.html%23flu_ug_sec_vof_dpm   There is/was a tutorial on the Learning Hub, but not on the (free) public last I checked.
    • SRP
      You can use TUI command: file/export/particle-history-data.
      You can refer to TUI command list: Chapter 5: file/ (ansys.com)
      Thank you.
    • Keshav Sharma
      Thanks for your insights but the issue is i am using student version hence can't register myself on customer portal.
      Is there any other way ?
      Click on Help in the Fluent Solver and then paste the link into a tab in the browser that opens. The solver has a built in token/cookie/biscuit that bypasses the password protection.
Viewing 4 reply threads
  • The topic ‘VOF model’ is closed to new replies.
