September 24, 2019 at 11:03 am
jlhee
SubscriberHi all,
Does anyone knows how to effectively view Iso-surface of Vorticity (like Q-Criterion) in ANSYS Fluent.
I have flow going through 4 vanes with casing at outer periphery, how do I visualize the vorticity in the flow?Â
Is there an input that I can use?
Thanks.
JÂ -
September 24, 2019 at 2:52 pm
Forum ModeratorThere's a vorticity magnitude available under the velocity contours, does that solve the problem?Â
September 24, 2019 at 2:55 pm
jlhee
SubscriberHi Rwoolhou,
Thanks for replying. I used Q-Criterion from Custom Function with a constant value. It looks fine for a particular instantaneous time-step.Â
Will look into your suggestion.
J-
November 30, 2023 at 12:17 pm
Aras karimi
SubscriberHi jlhee,
I am going to create exactly the same contour.
How can I do this?
I will be grateful if you provide me with an educational video.
- The topic ‘Visualizing Vorticity of a 3D blades in Fluent’ is closed to new replies.
