July 26, 2024 at 12:44 am
LoïcS
SubscriberHi,
I setup a 3D model with a dynamic mesh: a plate moving normal to a wall of the volume. I am able to preview the motion of the plate but not the deformation of the mesh since the mesh is only display on faces. Please, how can I display the mesh in the volume to be able to view the deformation of the mesh during the plate motion?
July 26, 2024 at 12:50 pm
Federico
Ansys EmployeeHello Loic,Â
you can create a plane surface (z = constant) that cuts through the middle of your moving plate and display the mesh on this plane when previewing the mesh motion.
July 26, 2024 at 12:51 pm
July 30, 2024 at 10:30 am
LoïcS
SubscriberHello Federico,
I'm interest to save the animation of the deforming mesh. In CFD post, i did a iso plane to be able to see the mesh deforming but it is not case. Please how can i do that? -
July 30, 2024 at 7:37 pm
Federico
Ansys EmployeeTo save a transient animation of the mesh, you will need to create your animation object prior to running the Fluent simulation.
July 30, 2024 at 7:38 pm
August 1, 2024 at 4:20 pm
LoïcS
SubscriberThanks Federico!
Please How to play saved animations when opening fluent again?
- The topic ‘View deformation mesh’ is closed to new replies.
5824
