TAGGED: acoustic, composite, noise-and-vibration, shell
May 13, 2024 at 10:36 pm
castrohenrique0208
SubscriberHello!Â
I am trying to perfom an acoustic simulation using a composite shell model.
Can anybody help with a guide?Â
Is it possible to create an enclosure of a surface using spaceclaim?
I'm trying to create but it shows an error " the selected body could not be subtracted from the enclosure body " -
May 14, 2024 at 6:24 am
ErKo
Ansys EmployeeÂ
Hi
Likely what you have is a shell/surface with acoustic domain on both sides. Unfortunetaly we can not have an acoustic domain on both sides of a shell/surface body.
Try using a solid body where this is not an issue (as 3D solid has a 3D thickness we can have an acoustic domain all around it).
All the best
Erik
May 14, 2024 at 2:34 pm
castrohenrique0208
SubscriberI forgot to mention you.Â
May 14, 2024 at 2:28 pm
castrohenrique0208
SubscriberThanks for you answer Erik.Â
I'm working with a composite shell/surface that I need to put into ANSYS ACP and, if I use a solid body, it will be impossible to open ANSYS ACP, because ACP only works with shell elements.Â
Am I wrong?Â
Is there any other way to perform the vibration/acoustics of a shell composite?Â
May 14, 2024 at 3:33 pm
ErKo
Ansys EmployeeÂ
Think you can have solids for ACP – as I do not use this I can not help much more – perhaps some other forum members can help out.
May 14, 2024 at 4:05 pm
May 16, 2024 at 5:53 am
ErKo
Ansys EmployeeHi
As I said I do not use this (ACP), so I can not help much more with ACP. Perhaps some other forum members can help out.
Erik
- The topic ‘vibro-acoustic simulation’ is closed to new replies.
5809
