Very small velocity in multi-phase analysis
    • dinhan0394
      Hi everybody,
      I am trying to perform a multiphase problem but encounter some errors. Hope everyone can help me.
      Description: Problem has two phases (water and gas) and boundary conditions as shown below
      Set up the solver
      Phase distribution
      Result: velocity at the end of the water phase is very small (0.02m/s) compared to other regions.
      Question: Is my setting so suitable? Is there a way to fix this phenomenon?
      Thanks
    • dinhan0394
      Please help me.
    • DrAmine
      Can you check your materials (densities). It looks like you have high re-circulation.
      Is it an open channel flow case? You can use the open channel flow which could help you setting up a good initial field and pressure boundary.
    • raul.raghav
      You've activated gravity in the -ve Y direction (UP based on your figure) and water would tend to go in the -ve Y direction (again UP based on your figure) due to gravity. That is the reason why you're getting very low velocities at the outlet.
    • dinhan0394
      Thank your for your help.
      I tried with Deactivate gravity but result not good.
      Here is  result: https://www.youtube.com/watch?v=XPlt6KlxYGw
    • dinhan0394
      Thank your for your reply.
      I used the material with all properties default in Fluent.
      I'll try with Open Chanel flow and tell you if have results.
    • dinhan0394
      Hi abenhadj,
      I tried with Open Channel Flow and here is result: https://youtu.be/6nleab2D6sc
Viewing 6 reply threads
  • The topic ‘Very small velocity in multi-phase analysis’ is closed to new replies.
