Electronics
Electronics
Verify conduction path ‘Path1’
    • Martina Lazzari
      I'm using Maxwell Student 2023 R1 to run a simulation AC Conduction for testing an interaction between blood and two electrodes, but when I enter the dielectric characteristics of blood and I run the simulation, it stop working and shows the following error:
      "Verify conduction path 'Path1': if a conduction path contains current exitation(s), it must contain at least one Voltage or Sink exitation but not both"
      Concerning excitations I'm using two electrodes, one with a current on the lower face and the other one with a sink, always on the lower face.
      How can I check where the problem is?
    • Reshmi Raghavan
      Hello Martina,
      Please check the below points.
      1) Are both the electrodes part of a single conduction path? - check the conduction path
      2) If they are not part of a single conduction path current in and sink has to be defined for both the conductor.
  • The topic ‘Verify conduction path ‘Path1’’ is closed to new replies.
