June 19, 2025 at 11:19 pm
J.T.
SubscriberI'm attempting to follow the VBM propeller tutorial in 2025 R1 and keep getting the following error.
Node 999999 Fatal signal raised sig = Segmentation fault
 93afd700 CX_Primitive_Error
 244fb9d0 log2f
 93b748d0 logical_right_shift
 1c76e530 _C_specific_handler
 272d5bc0 _chkstk
 2724de30 RtlFindCharInUnicodeString
 272d4cc0 KiUserExceptionDispatcher
 9257fa80 vbm_read_input
 93b5e940 eval
 93b5e940 eval
 93b5e940 eval
 93b5e940 eval
 93b60e00 set_cc
 93b61850 eval_errprotect
 93b5e940 eval
 93b5e940 eval
 93b5e940 eval
 93b5e940 eval
 93b60e00 set_cc
 93afe7c0 CX_Interpret_String
 917bf450 rpgetvar_errprotect
 26672580 BaseThreadInitThunk
 2728af50 RtlUserThreadStart
 244fb9d0 log2f
 272d5bc0 _chkstk
 93b5e940 eval
 93b5e940 eval
 93b5e940 eval
 93b5e940 eval
 93b60e00 set_cc
 93b5e940 eval
 93b5e940 eval
 93b5e940 eval
 93b5e940 eval
 93b60e00 set_cc
 2728af50 RtlUserThreadStartÂ
June 20, 2025 at 9:15 am
Forum ModeratorWhat step are you at?
June 20, 2025 at 3:32 pm
J.T.
Subscriberhitting apply at the end of 34.2.3.12. Rotor Inputs
June 20, 2025 at 3:43 pm
Forum ModeratorCan you double check the file format and for white space characters.Â
June 20, 2025 at 4:12 pm
J.T.
SubscriberI am taking this directly from the tutorial zip file. There was an extra new line at the very bottom that I removed but see the same error.
3301
1036
1006
859
804
