TAGGED: continuity-residuals, sliding-mesh, turbine-rotation
April 26, 2025 at 4:47 am
rosyadaamron
SubscriberHello,
I've done a transient analisys of a savonius turbine using mesh motion. the domain is rotating also the turbine (wall). i didn't change anything in URF.
The residual graph that i got looks like never go down to 1e-3. The drag force from the turbine is also oscillating, but the pattern is constant. Is my result converged? did i do something wrong? like is it true that in Sliding Mesh (Mesh Motion), the only part which is moving is the fluid (domain), not the turbine (wall)? -
April 30, 2025 at 1:42 pm
Federico
Ansys EmployeeHello,Â
from your Drag plot, it appears that your results are stable. Generally, we recommend 3orders of magnitude decrease during a time step for the residuals. You can verify your results by allowing more iterations per time step to see if converging the intra-setp solution further improves or alter your drag results at all.
- affinity not set
3967
1420
1272
1119
1015
