October 25, 2024 at 12:04 pm
cma6301
SubscriberHello,
I want to see the effect of density change in my simulation as the simulation is running. Is it possible to write a script in Rocky that can do this? I want to see the change in behavior of particle in my system as the density increases.
Thanks with regards,
Ayuk
October 29, 2024 at 12:23 pm
Lucas Bertollo Baggio
Ansys EmployeeHello,Â
What density change do you want to analyze? Particle's density change?Â
How is density increasing?!Â
October 29, 2024 at 10:40 pm
cma6301
SubscriberIn wet grinding there is a point when the content of the mill become sticky. But before this point the density of the content changes are the mineral become fine. I want to mimic this phenomenon in the simulation. Reasons why I need to change the density of the content in the simulation if that is obtainable.
Best regards,
Ayuk
October 31, 2024 at 8:00 pm
Ansys EmployeeAyuk,Â
Are you simulatin DEM-SPH? or DEM-only?
You can check the particle's density or SPH element's density by accessing the Properties tab on the Data Editors and plotting Density in a Time Plot.Â
October 31, 2024 at 8:05 pm
cma6301
SubscriberHello Lucas,
Thank yo so much for the quick response,
I am simulating DEM-SPH.
Best regards,
Ayuk
October 31, 2024 at 8:23 pm
cma6301
I cheeked the SPH element's density and I plotted it aganist time. However, the graph shows a constant density throughout the entire simulation. I am expecting to see the density increasing then form a plateu at some point.
Back to my question
Is it possible in Rocky to model the SPH density such that it a constant say 10kg/m3 at t=0s and increase to say 400kg/m3 and for a plateu at some point and it continue being at that constant value for the rest of the simulation time?
November 4, 2024 at 11:12 am
Ansys EmployeeAyuk, our SPH models are "Weakly Compressible (WCSPH)" or "Incompressible (IISPH)", so density oscillations are not expected.
I can't see how the density would vary this much. Are you using any custom module?
5804
