January 23, 2024 at 9:08 am
taketoshi.nakayama
SubscriberTo whom it may concern I am trying to calculate a directional coupler composed of rib waveguides.
Is it suitable to use varFDTD in this case?
I understand that varFDTD is suitable for channel waveguides.
I don't have a lot of computing resources, so I am having trouble with FDTD because it is very time consuming to calculate.
Also, is there any other way to calculate accurately and quickly other than varFDTD?
Thank you in advance.
January 24, 2024 at 10:56 am
Dimitris Polyzos
Ansys EmployeeHello Taketoshi,
In general, varFDTD is used for planar geometries where there is negligible coupling between vertical modes. varFDTD solver is based on collapsing a 3D geometry into a 2D set of effective indices that can be solved with 2D FDTD. This works best with waveguides made from planar structures, as the main assumption of this method is that there is little coupling between different supported slab modes. For many devices, such as SOI based slab waveguide structures, that only support 2 vertical modes with different polarization, this is an excellent assumption. varFDTD can achieve accuracy comparable to 3D FDTD with computation times comparable to 2D FDTD. Also, varFDTD is able to approximately simulate rib waveguide as it gets the "effective index" anywhere is the simulation region. However, varFDTD is quick but 3D FDTD is advised to verify the varFDTD results.Â
An alternative to varFDTD would be to use FDE and EME solver. With FDE you will be able to calculate the neff of the waveguide while with EME you will calculate the s-parametres transmission/reflection coefficients. For 3D geometries where there is coupling between vertical modes, EME is a frequency domain method that offers a good alternative to 3D FDTD because its computational requirements scale exceptionally well with distance. Please refer to the following articles:
Ring modulator - transient response (varFDTD)
I hope I helped.
Dimitris
January 29, 2024 at 2:20 am
taketoshi.nakayama
Subscriber -
January 29, 2024 at 2:29 am
taketoshi.nakayama
SubscriberMr. Dimitris.
Thank you for your answer.
I found that in this case the light does not rotate to different polarizations, so the simulation is possible.
Also, your reference page was helpful.
Thank you very much.
- The topic ‘varFDTD’ is closed to new replies.
6249
