Vapor Quality -Multiphase VOF Ansys Fluent
    • samiasadaf_uetian
      Hello everyone...I am working on flow boiling through microchannel using Multiphase VOF method on Ansys Fluent (Transient flow)
      I am new to ansys and also to this research topic and have started from relatively a simpler geometry (horizontal 2D rectangular channel with 70mm in length and 1mm in height)
      Boundary conditions : Inlet: velocity 0.01m/s temperature:372.14K, Outlet : 0Pa, temperature 300K, Upper heating wall: 374.15 K ,Lower heating wall :374.15K (for bubbly flow)
      initial liquid fraction is 1 and vapor fraction is 0.
      I have got the vapor and liquid volume fractions for bubbly and semi slug flow which are increasing and decreasing with time respectively.
      but when I plot these fractions along the length of computational domain...they are showing huge fluctuation.
      Secondly, I need to calculate the vapor quality. I am confused about calculating it.
      in Some articles ,it has been calculated using mass flow rates .
      whereas in others, it is calculated based on enthalpy formula.
      in post CFD, the values of mass flow rates are in -ve ...should I consider -ve sign while calculating...
      and similarly enthalpy values are also in -negative.
      please help me with calculation of vapor quality
      Thanks
      Some images will help with the volume fraction question.
      Please define what you want to check for vapour quality: quantity is usually enough for most models. Mass leaving the domain is always negative, enthalpy is a function of temperature, reference temperature & phase.
  • The topic ‘Vapor Quality -Multiphase VOF Ansys Fluent’ is closed to new replies.
