March 10, 2020 at 1:54 pm
Gijoys4v
SubscriberHello Ansys,
For the last few days I was trying to simulate a tensile experiment for the model given. The experimental setup and the obtained graph from the experimental work and from my simulation is given below.
when I tried to simulate the model I obtained answer that is too big than the obtained value . there is no problem in the material properties and I tried after mesh convergence study. I simulated the model by taking the symmetry. To one end symmetry boundary condition given and to the other end a displacement of 1% of total length of the model is given
the model is a four layered thin film. Also I had given some prestrain to the model which occurred during its cooling process. the length of the model is 300mm and thickness is only 0.1mm and the width is 5mm.Â
I am stuck and cannot proceed. Any help will be really appreciated. Please help me to resolve my problem. please tell me where I went wrong.
The file is also attached
March 10, 2020 at 4:07 pm
March 10, 2020 at 4:15 pm
Gijoys4v
SubscriberHello Mr. Peter,
thanks for the reply. Yes I wanted to give a negative strain (which is actually the residual strain within in the thin film which occurred due to the cooling)
March 10, 2020 at 6:23 pm
peteroznewman
SubscriberDid you double the displacement in your half model to represent the full model when you plotted the force and compared it with the experiment?
March 10, 2020 at 6:39 pm
Gijoys4v
SubscriberTo the half model, after giving symmetry to one end, I had given only 1 percent displacement of the length of the model taken. As I took only half of the model (which is 150mm), I gave displacement of 1.5mm only -
March 10, 2020 at 6:40 pm
Gijoys4v
SubscriberAnd the force, I took from reaction prob. -
March 13, 2020 at 12:15 pm
Gijoys4v
SubscriberAny suggestions or help will be really appreciated .
whether my method is correct?
March 13, 2020 at 2:01 pm
peteroznewman
SubscriberRerun your model with double the number of elements through the thickness to see if that changes the result. If it does double it again. This is called a Mesh Refinement Study.
A screen snapshot of a spreadsheet would help with setup data such as Exp. Sample Length, Mod. Sample Length
and columns such as:
Exp. Disp., Exp. Strain, Exp. Force, Model Disp. Model Strain, Model Force
Next, assemble a list of all the parameters that have a range of uncertainty.
- Length
- Width
- Layer 1 Thickness
- Layer 2 Thickness
- Layer 3 Thickness
- Layer 4 Thickness
- Layer 1Â Modulus
- Layer 2 Modulus
- Layer 3 Modulus
- Layer 4 Modulus
- Layer 1 CTE
- Layer 2 CTE
- Layer 3 CTE
- Layer 4 CTE
- Delta T for Layer 1
- Delta T for Layer 2
- Delta T for Layer 3
- Delta T for Layer 4
Assign a range for each uncertainty, then assign the worst case for each parameter that will push the Force higher or lower and label those values F+ and F-. Run a model with all the parameters at F+ and run another model with all the parameters at F- and show the possible variation in the model caused by variations in the input to the model. See if your experimental result falls between the F+ and the F- curves.
- The topic ‘Validation and simulation comparison’ is closed to new replies.
5654
1885
1404
1303
