LS Dyna
LS Dyna
Using Usermat version of MPP DYNA R14 on HPC
    • dylanmc3
      We are currently trying to run a set of simulations on TACC's Stampede3 using our own Linux executable for MPP DYNA, which has a user-defined material model. Is there any information/guidance on how to do this correctly (e.g. which files to move to the HPC and command lines to run analyses)? I reached out to TACC and they did not have any information on this besides the information on this link: https://docs.tacc.utexas.edu/software/ansys/.
      Thanks in advance
    • Vijay
      The LS-DYNA Keyword Manual Volume 1 offers detailed insights into User-Defined Materials, particularly in Appendix A. You can access the manual through the (https://ftp.lstc.com/anonymous/outgoing/web/ls-dyna_manuals/DRAFT/DRAFT_Vol_I.pdf).
      If you need to download object files, visit (https://ftp.lstc.com/objects). Note that credentials are required to access these files, which can be obtained by reaching out to your LS-DYNA provider.
