Using thermal control logic in transient model
    • suraj9735
      Thanks, Peter!
      It really helped me.
      Now next I want to put heat flux on or off according to programmed control.
      I want my model maximum temperature should not exceed 180 deg and also not fall below 175 deg.
      how to put logical heat flux load like below
      0180 deg=1500 Watt.
      Temp>180 deg=0 Watt.
      Thank you!
      This new discussion was moved from the tail end of a solved discussion.
      Suraj, I don't know how to do this, but will be interested to find out.
      Peter
    • mrife
       Hi Suraj9735
      There is a 'combination' element in Mechanical APDL that can act as a thermostat.  See the two part blog entry on this at PADT - the link to part 1 is:
      http://www.padtinc.com/blog/the-focus/act-extension-for-a-pid-thermostat-controller-part-1
      Mike
  • The topic ‘Using thermal control logic in transient model’ is closed to new replies.
