Using the degenerated tetrahedral and pyramid shapes for SOLID185
    • vganore
      Is using the degenerated tetrahedral and pyramid shapes for SOLID185 recommended?
    • Arun Kumar
      No. SOLID185 is a lower order element without mid-side nodes. Section 2.5.1 of the MAPDL Element Reference Manual contains a detailed discussion on why using "degenerated elements formed from quadrilateral and brick elements without mid-side nodes" is not recommended. Here is the link to that section of the Help System. help/anselem/HlpECH28.html Also, Benchmark C1 from the Verification Manual contains a sample model that demonstrates that using degenerated lower order elements can produce inaccurate results+. Here is a link to the section of the Help System. help/ansvm/HlpV_VMC1.html
  • The topic ‘Using the degenerated tetrahedral and pyramid shapes for SOLID185’ is closed to new replies.
