March 17, 2024 at 12:42 pm
kagankarakusx
SubscriberI know that we can extract the s parameters of a trace from Ansys siwave and convert it to the rlc spice equivalent circuit. Can we use this closed box s parameter model directly as a port for circuit simulation on the electronics desktop?ÂOr should we create an rlc spice equation model from s parameters? -
March 18, 2024 at 4:42 pm
March 19, 2024 at 1:15 pm
Dan Dvorscak
Ansys EmployeeAs Aymen pointed out you can use that icon to directly link to the SIwave project. And yes, in that case SIwave will directly provide the Circuit tool in AEDT with the solved s-parameters from the SIwave project. But to go back to the initial question, yes the circuit tool can handle s-parameters directly without having to convert to an equivalent circuit model. If you the "Nport" icon in the Component Libraries window, that will allow you to point to any arbitrart s-parameter file. Touchsone files are the most common ones used for this.Â
Best regards,
-Dan
- The topic ‘Using SYZ Parameters Back box port Model Directly in Electronics desktop’ is closed to new replies.
1330
1097
