June 22, 2023 at 2:13 pm
Leonid Pascar
SubscriberHi,
I think about a component that the output will be routed according to input field. I need to optimize the sturcture for a few input fields. Would it be possible to run a LumOpt optimization that will use multiple field sources? Are there any examples?
Thanks,
Leonid
June 23, 2023 at 8:22 pm
Guilin Sun
Ansys Employee Lumerical does not have similar examples online.You may need to modify the Lumopt as current version does not have this functionality. You could find more information on Lumopt Github.
- The topic ‘Using Multiple sources in LumOpt Inverse design’ is closed to new replies.
1890
1419
1304
